Why Preventative Maintenance is Essential for Waterjet Performance
Preventative maintenance isn’t optional for waterjet operations – it’s the difference between predictable performance and costly downtime. With the right maintenance approach, waterjet systems can deliver reliable, high‑quality cutting for 15–20 years or more.
According to Michael Albert, Application Specialist and resident Flow waterjet expert, consistent maintenance is one of the most overlooked drivers of long-term waterjet success. “It’s really like your car,” Michael explains. “You don’t drive 100,000 miles without changing the oil. Waterjets are no different – you maintain them to keep performance where it should be."
Why Preventative Maintenance Matters for Waterjets
Preventative maintenance directly impacts:- Uptime and production consistency
- Cut accuracy and edge quality
- Total cost of ownership
- Overall machine lifespan
What Basic Maintenance Does a Waterjet Require?
While maintenance frequency depends on application, usage hours, and system configuration, most waterjets share core maintenance needs.Key components to monitor regularly:
- Nozzles and orifices
- Cutting heads and mixing chambers
- Abrasive delivery and abrasive levels
- Pump filters and seals
- Lubrication and grease points
Why the “Break Fix” Approach Fails Waterjet Owners
Waiting until something breaks is one of the most expensive maintenance strategies.A reactive, break fix approach:
- Increases unplanned downtime
- Disrupts production schedules
- Raises repair and replacement costs
- Reduces long-term system reliability
When Should You Call a Professional for Waterjet Maintenance?
Operators can, and should, handle routine inspections and basic upkeep. But major service, rebuilds, and diagnostics are best handled by trained professionals. Studies show that companies handling all maintenance internally can spend 50–60% more than those using outsourced preventative service programs.Flow’s service and support programs are designed to help customers:
- Establish predictable maintenance schedules
- Access factory-trained technicians
- Order OEM parts quickly and reliably
- Receive training and preventative insights
How Long Can a Waterjet Last With Proper Maintenance?
With consistent preventative care, waterjet systems can remain productive for decades. “I’ve seen 15 and 20 year old machines still running strong,” Michael says. “The owners took care of them – and it shows.” Longevity isn’t accidental. It’s the result of disciplined upkeep, early intervention, and the right support partner.
Common Waterjet Maintenance Questions (Quick Answers)
How often does a waterjet need maintenance?Maintenance intervals vary based on usage hours and application, ranging from weekly checks to service intervals every few months.
What happens if waterjet maintenance is skipped?
Skipping maintenance increases downtime, reduces cut quality, accelerates component wear, and leads to higher repair costs.
Can waterjets really last 20 years?
Yes. With consistent preventative maintenance and professional service, waterjets can operate reliably for 15–20 years or more.
Is outsourced waterjet maintenance worth it?
In most cases, yes. Outsourced service reduces total maintenance costs and improves long-term system reliability.
The Bottom Line: Preventative Maintenance Protects Performance
Preventative maintenance is one of the highest ROI investments a waterjet owner can make. Clean systems, timely part replacement, and professional support ensure consistent performance, predictable uptime, and long service life. Or, as Michael would put it: take care of your waterjet – and it will take care of your business.
